Rlauro5202
1992 Sea Doo GTX 5860. Prior owners butchered carbs. Purchased two new Mikuni BN38-34-8113's, description stated for single, dual and triple installs.
Installed exterior hardware on the carbs to accomodate Mag and PTO sides, units fit perfect onto manifold intake.
Question: Do these 8113's need to be modified internally? The Pilot is 65, Main: 107.5, Needle/Seats 2.0. Checking the original BN38-34's it appears they use the same jet sizes. I recall reading somewhere that the carbs have 62.5 pilot and 67.5 pilots, not sure if this is accurate, and if it is, which carb gets which pilot? Obviously I don't want one cylinder running hot, seizing or blowing the engine.
Also, the return fuel lines in these original carbs have restrictors: Mag 3.0mm, PTO 0.5mm from the PWC's Sea Doo Shop Manual. I don't believe the new 8113's have restrictors, so if I need restrictors, can they be installed on the actual fuel lines at each carb? Best way to do this? I've heard using a 3.0 mm jet and 0.5mm jet zipped-tied to each fuel return line?
Much appreciate experienced advice here. I don't have the experience obvioulsy and I am "on my own" with this ski -noone wants to deal with it due to its age, which I understand. My son bought it and trying to help him and be a dad.
Thank you, much gratitude.
Rob
Rob
