AA-51
Hi guys long time lurker but I cant think of anything else at this point and I'm open to suggestions,
Short backstory:
A couple months ago I picked up a 1992 GTX for cheap. Its in good condition the PO was parting with it because it would run but not shut off with the lanyard or off kill button. Easy enough so I swapped out the MPEM and problem fixed and it ran great. After the maiden ride however it lost power and died on the way back to the dock which I thought was odd but ok so back to diagnosing issues and there is nothing coming out of the coil even though it is getting signal. Ok so I replace the coil and we are back in business and running great again. Had it out for a weekend at a buddies cabin and the first day it ran great all day no issues but the second day it was very hard to start but I eventually got it then proceeded to suck up a ski rope immediately... managed to cut that out and got it back in the water and was running good again until my buddy came back and said hit a wave and it died in the middle of the lake. He was able to fire it up and idle back but it sounds like its running on one cylinder or a bad misfire or something.
So when I got it out of the water I noticed a couple motor mounts busted so I thought maybe the pump was getting hung up because of misalignment and making it run rough so I replaced all the motor mounts and made sure the engine and pump spin freely. There was also more than a usual amount of water in the hull which I contributed to sucking up that rope and getting it wrapped up between hull and shaft. Anyways, went to fire it up and still it sounds like its running on one cylinder or misfiring I cant really tell and wont rev at all and barely holds this rough "idle".
So far I have checked that it has spark, good compression, seems to be getting fuel (plugs wet), carbs are clean, rotary valve gear isn't stripped so I don't see how the actual valve plate could've moved. I really just don't know what else to check from here. I don't think the problem is internal to the engine and I'm hoping I don't have to pull it out.
Sorry for the wall of text any suggestions welcomed
Thanks,
Andrew
Short backstory:
Thanks,
Andrew
