hollywoodbadguy1
you boyyyyys lol
ok DR said that being im not getting current out of ignition modual and getting current from 3 wire plug thing from the rotor
and the IG/mod is known to be good. that to check the rev limiter.
well im under the understanding that there is no way to test the RL. soooo i should check the Stop Button? how do i check that?
forgive me if i seem stupid. im not just frustrated. and exercising patients.
now i do have the same 90 sp that works should i try taking the Rev limiter out of that and installing in in the one in question? its allot of work to test. or is there a shorter way?
Is there a way to disconect Rev limiter and apply current to close or re set it? just a shot in the dark.
swap rev limiters?
test Stop or kill switch?
pull out last or remaining hair?
go spend $300.00 at shop that is 30 miles away?
lol once again thanks so much Frankie Ray your hollywoodbadguy1
swap rev limiters?
