good Question
I know the low speed idle screw as the one w/ the spring on it connected to the throttle lever. This one I have not touched. Upon rebuilding the carb, the only adjustment screw I removed and cleaned was a small brass screw, w/ a small hole in the end, inside a hole. There was not a cap on top of it but it looked like a plug type cap could fit inside of the hole that the screw was set in.
Before removing, I checked the screws position by turning it clockwise, it was tightened all the way, therefore I thought it was ok to remove it since it did not have a setting. I proceed to clean it and make sure the hole was not blocked.
This was the only screw on the carb so I assume it is the one you are talking about, please confirm?
Running it was dry and on the trailer. Once I get it running I will turn on the water. Is this method correct?
Thank you!
