hollywoodbadguy1
Hay Boy's happy summer.
here is the deal.
i have 2 1990 bombadiers.
got one working whoooo hoooo. i put the 95 carb in it and it runs better.
the other. im having trouble it this area.
Im not getting current to the spark plugs. so i tested the three wire connector comeing out of the Magnito. no current. i had the same condition with the other one but cleaned all connections and got sparks. now the previous owner said it wasent flushed out so i figured that maby the magnito and or fly wheel were rusted.
TOOK OF FLYWHEEL.
flywheel totaly rusted inside and about 5 teeth were broken.
GOT another flywheel.
cleaned contacts on magnito made sure all were clean.
installed flywheel.
am getting current out of Three wire connector from magnito. COOL Progress
but no current out the other side of IGNTIGION MODULE.?
took off Ignition Module from the second doo that runs. to see if it was the Module. made sense to me. Installed suspect IM on running doo and worked fine
hooked up Ignition Module. from running Doo
still no current comeing out of IM. that i know is good. now there is current comeing out of 3 wire connector from magnito.
cleaned 3wire connector ruffed up and closed gap on connectors to insure good connection. still no current out of IM?
Now i noticed that on the good running doo. the voltage comeing out of one side, 3 wire connector from magnito was positave and the other side neg.
but when i test 3 wire from magnito on the doo that is not running
both sids are showing Positave?
this dosent make sense to me but im not and expert by any means.
if the ignition modual works on one doo, and there is current comeing from the magnito. but no current exiting the IM one that is known to be good. ??????
kind of stumped. do i need to take of flywheel, magnito. and check for. grounded 3connector wire comeing out of Magnito. and trace it back further?
any and all help is always appricated. sorry for the long explination.
Frankie Ray your Hollywoodbadguy1. ps there are no shops in malibu or santa monica that i can take it to. thank you.
here is the deal.
TOOK OF FLYWHEEL.
installed flywheel.
