Hi, working on 88 gts for a friend. Info-unit sat quite some time,when I ck,d
it over unit would not crank. Removed and replaced starter relay in electrical
box. (looks like it has been replaced before). Eng has good compression and ignition--problem is ignition only hot in crank mode. If I hold starter button
engine will run -as soon as you let off button ignition dies. I,m sure I have a
kill circuit-or something that is not wired correctly. Carb has been removed and cleaned,etc. How should system work-possibly need a wiring diagram to ck.
Thanks for any help-I,m so close but so far away from fixed!
