I took my 82 JS550 out to the lake and it would run fine at idle and will start to pull once given throttle, but it will not get off of the plane. If I hold it at WOT it will start to slow down and eventually will die. Once it dies it takes about 10 min of it sitting before it will restart.
I checked compression and each cylinder is at 135, and the carb/fuel pump was rebuilt. The ski has new gas mixed at 40:1, and it has new NGK br7es plugs. Both cylinders are firing. Im thinking its the high speed fuel screw is wrong. I spent 2 hours trying to tune it in by making small adjustments at a time but it never got better or worse by doing it.
And finally does anyone have Carb settings for the 82 JS550 as well as fuel line routing?
