Pistol_pete487
Hello hoping some body with more knowledge then me which isn't alot with seadoo can help me diagnose my 1996 changeller I've put 3 r.a.v.e kits on it the past 2 years and after a few hours they melt I have 150psi in both cylinders. I just took the cylinder head off and noticed alot of carbon build up on both pistons.I've read on other post that lack of rave vavle maitance can cause excessive wear in the guillotine solt causing more heat then normal. I'm the 3rd owner of the boat the owner before me rebuilt the engine and due to bad decisions on my end I went in too shallow water the second day of ownership and sucked up a rock and snapped the drive shaft. I have sense fixed that problem last summer replaced the jet pump again due to taking it to a shoty mechanic who broke my fins in the pump not thinking to look inside it I assumed it was a power vavle problem which was causing it to not plain out also the top red screw was melting on the pto side so I had them both replaced. But every few hours of use they go bad im wonder if I should order new jugs pto and mag. I'm also in the process of going threw carb and changing out grey fuel lines thanks.
