lithium2g
Hi,
Disclaimer: I've scoured every thread/youtube in relation to RAVE's on 787 engines and I have learned a shitload in the last few weeks. Actually enjoying learning and understanding this stuff...from a nursing background. But Im at a loss and can't find the answer to my questions.
98 Seedster, owned for 2 months, 20 hours on the water so far. RAVE valve red cap found to be melted upon random inspection after 4 hours on the water for the day. Stopped the engine, called it a day. Watched every youtube video pertaining to RAVE valves and felt confident in pulling it out to inspect. Confirmed it had in fact melted internally and saw the guillotine had a big chunk missing off it. Refer to pics. Based on the thick layer of hardened exhaust shit all over it I am inclined to think the guillotine had wasted away over time and continued to function (poorly?) in that state. (the image isn't indicative of this because I practiced cleaning it up before taking this picture!)
I purchased a full RAVE rebuild kit on ebay - It should arrive tomorrow. It looks similar to this pic https://www.picclickimg.com/d/l400/pict/362425962730_/Sea-Doo-787-800-XP-GSX-GTX-Exhaust.jpg
I am suspicious the seadoo guys here did not inspect this particular RAVE valve when it was serviced a month ago. They did rebuild the other RAVE on the other engine because it was melted upon purchase. They had trouble sourcing parts (took me 20 seconds on ebay but whatever) and ended up using 2nd hand bits and some new parts. Anyway I pulled that RAVE valve to have a look at it for comparison and give it a clean. I notice there was no small spring ring that fixes the diaphragm to the the valve base. Refer to picture. It was just sitting on there tightly but not fastened with the ring. Everything else seems in order and so I don't know whether I should order and install the small spring ring or just put it back how it was. What should I do?
I tried to pull the other RAVE's out to inspect and clean but I can't pull them out without the engine getting in the way and I don't know how it is suppose to be done. What am doing wrong there?
Lastly, the RAVE rebuild the seadoo guys did last month, the RAVE black cap used has these two screw holes on the side so that it can be screwed down into the metal housing instead of using the metal fixing clip. I chopped one of them because the metal clips just wouldn't go over it. Refer to pic. Is this bad?
