Scooper, we've all had this conversation a few times about the importance of not jumping the Seadoo's.......This may result in electrical failure due to shorting.......but that's where it ends for me.
I'll have to disagree with DAWG on the jump boxes, because it's the same thing as having two batteries in the boat and using a selection switch to run one, both or off.
The issue with jump starting the engine has to do with the electrical system of what your jumping from. When you hear the phrase, "do not jump start". This is entirely based on the idea that jump starting is done with the other engine your starting from is running. This is where the electrical failure can come from. Because the battery itself holds about 12 vdc, it's o.k. to jump from that battery, with that vehicle off. But running, that vehicle's charging system comes into play with your electrical system, which is now sending 14 vdc to that battery your jumping from.
If you jump start your craft, make sure tha vehicle your starting from is off. Then, you can safely jump start.
Now, I know there will be a lot of debate about this but I, myself have done this many, many times with no problems. I have also used my charger on high amps to get a quick charge for a start.
We all talk about these electrical systems and the damage that can be done. But there not that tempermental. They also have fuese to help protect them, including the most important, the MPEM. There is risk of electrical back feed into the mpem, but hell, you can do that yourself from your own battery while messing with your system.
The last note.........I do agree with Dawg again on "don't be so cheap, buy a damn battery!"..............:cheers:
