Luv2Camp
My 95 GTX smokes quite a bit. When I bought it and did the first start up of the season and pissed a puddle of oil out. Have been running it now for several months and no leaking oil and no hydro lock but will still smoke out the garage if I start it. In the water, it smokes but not too bad.
Just rebuilt the carbs using genuine mikuni parts. Plugs get oil on them but still runs fine. Assuming that the oil on the plug is due to the oil leak and not that it is running too rich. Thoughts?? Also, checked compression with an OTC compression gauge and both cylinders are at 140. Not finding much around when to get concerned about compression. Is there a bottom end range that I should stop riding and go with an SBT? Just do not want to push my luck and wind up with a major core charge when I go to swap out with the SBT. I can get the ski up to 50 (based on the Seadoo spedo, have not used GPS to see actual speed)
