richardsu
Hello All,
Hoping somebody out there can help me. The problem I have is that every time I start the engine, it runs for about 1 second then blows the 5 amp fuse in the front electrical box. I have disconnected everything to try and eliminate the problem, including the VTS, gauges, fuel & oil senders, etc, but to no avail. I don't believe it is the MPEM as I had that replaced less than 2 running hours ago, and besides, it makes all the right sounds, ie. two beeps when I plug the lanyard on.
From reading various posts, I have a feeling that it might be the trigger coil or stator shorting out. I've heard the trigger coil brackets on the XP are notorious & fail causing the coil to short out. I've ringed the trigger coil out with an OHM meter and it tests fine, but I heard they can screw with your mind as they will short out to ground once engine is kicking.
Another possibility may be a faulty regulator/rectifier. Is there a way of testing the regulator?
Before I go pulling off the magneto cover to check the stator & trigger coil, I was hoping I could get some confirmation that this is more than likely the problem.
Any comments will be greatly appreciated.
Richard.
Richard.
