seadoo_mike
What is the advantage going to riva washers over the ceramic, is it just the overall breakdown percentage, do you go with synthetic oil when you have the riva washers, is synthetic better for the motor overall. If you replace with ceramic and use the right mineral oil what is the difference. When its time to rebuild the charger do you get the whole kit or do you just inspect and replace the washers. Does the kit come with everything you need (shaft, bearings) trying to get an idea of what I need to do the job, I looked at manual from forum on charger and it looks like there might be a couple of special tools needed to do the job. When I looked at the parts list the charger kit was around $300, does that seem right.. Do you know what the around about total price would be to do the job with parts and needed tools and does the kit come with the right washers or do you have to pick them up also (ex: riva's) price of the riva's I saw where around $100, does that seem right.. Before the charger is pulled do you have to extract the engine oil. On the manuals page I did not see a supercharger section in the 2006 sportster manual, so I went on the 2007 4-tec manual and found the charger instructions, is that ok to use, are all the chargers pretty much interchangeable. I know this was alot of babbling but I'm just trying to get a hand on what I need to do for the job, and how much it will cost. thanks
