FunonH2O
I have a 2012 Sea-Doo, 180 Challenger! 260hp. I bought the boat used in Oct of 2020 with 95 hours on it. I found out the intercooler was cracked and since I live in Maine, the boat was winterized and into storage. In the spring of 2021, I had the dealer install a new intercooler, new plugs and rebuilt the supercharger. I use only ethanol free gas, no idea if the previous owner did. I used the boat all summer, but noticed an engine surge at lower rpm, less than 4500 but ok at idle. The surge was noticeable but not more than a 200 rpm change. The boat was winterized by the dealer and stored in Sept of 2021. I got the boat out and on the water in May of 2022. Now,all summer, it surges at most all rpm ranges and at max throttle will usually only go to 6800rpm. Once ina while at full throttle it will surge to 7800 but falls back to 6800 after only a few seconds at the higher rpm. Sometimes the surge is so wide ranging at about 5000rpm, that is seems to almost quit. It will accelerate smoothly, but at almost any throttle position, it surges significantly. I still use only ethanol free gas and now, at dealers suggestion, put in k100 at fill ups. Has anyone seen this kind of problem?
