Im building a custom river fishing boat. General specs, 17'6" x 68", .190 tempered bottom, tunnel haul with a finished weight around 2000lbs. I fish tournaments and I want something faster then the guys with the 200 opti sport jets. Ive looked into the 240 EFI and Id rather not go down that road. I really want to put the 250 opti sport jet in this boat. I found a used motor for sale from an engine builder. He will refresh the motor, install different reeds, WSM pistons and do some port work. He thinks the motor will be up around 270hp. I would be getting the motor and jet pump package cheaper then I could get a new 200 opti.
I also have a few questions with gear ratios and impeller pitch vs the 200 opti. I see the 250 has a slower pump ratio. Im curious if the 200 and 250 pumps use the same pitch impellers or if the 250 has a more aggressively pitched impeller for more top end?
Without getting into to many more random details im wondering what your general thoughts would be on this motor and build.
Thanks- Roost
Thanks- Roost
