Hi all,
So I've done a bunch of searching on this on the forums here, and I've found a lot of info, so here's what I have going on....
So I have a 2001 Challenger 1800, that had a blown engine when i got it. Replaced with a reman short block in 2008.
Was running well after rebuild.....only noticed the traditional startup smoke (due to the enrichment) that would clear up after starting.
Boat doesn't get many hours of runtime per year, then winterized until next year. I've been fighting water in my gas, but the addition
of a secondary 25um filter seems to have finally cleared this problem for me.
So, here's what's going on....
Cold start: engine will start fine, but runs low rpm (maybe 500-700). It appears to idle ok (but low), then the smoke starts increasing and the engine sounds like it's loading up and getting flooded out....once i get it in forward I can increase the throttle to about 2000-2500 and the smoke clears up and she purrs just fine. Good acceleration, no hesitation, good top speed. So, then I'll idle back down and the same symptoms begin.....low idle, the smoke starts increasing, and it may finally stall out. If it stalls out, she won't restart when hot.
Let it cool, she'll restart.
I've read several posts describing very similar symptoms on their 240EFI, and it seems the usual suspects are:
- port side temp sensor
- TPS sensor
I see posts about the problem, but few followups on what actually SOLVED the problem for you.
Can anyone chime in if they know what the most likely culprit has traditionally been here?
I haven't been able to test my temp sensor (will probably just replace) or the TPS sensor (my god WHY is that SO expensive?!?).
Any insight is greatly appreciated!
Thanx!
Dave
- TPS sensor
Thanx!
Dave
