ripcuda
The starboard head temperature switch (as labeled in the service manual wiring diagram) is the top sensor in the pic with only the single wire connector. This is an overheat "switch" in that at the set designed temperature, the sender grounds the single wire connector. This Tan/LtBlu wire then gives the grounded signal to the Ignition Control module and to the dash where I think it triggers a warning light (and buzzer?).
Q1: What is the temperature this triggers at?
-- I put the sensor in a pot of water and took it all the way to boiling 210-ish degrees F. It never triggered.
Q2: Does the Ignition Control module limit revs or go into a limp mode when this is triggered?
Cheers!
Cheers!
