I apologize in advance if this question has be covered previously... and welcome links to any threads on this topic..
I traded for a 2003 speedster with a bad Mercury 240. I’m looking into repairing the block as there is a crack in one of the cylinder sleeves that goes all the way through the water jacket that surrounds the cylinder. My question is: if this can not be repaired- can I use another Mercury outboard block as a replacement?... and which one? From what I understand- the biggest hurdle is the crankshaft splines being different ....I have a good crank from the old engine... is there a block I can swap this crank into without a lot of modification??
Any info you have to share would be greatly appreciated.
