2007 gti 130 will not start
jmacrae01
Cranks over fine has fuel pressure and engine has good compression and all three cylinders. Ran codes with the Candoo pro has code P0337 no crankshaft single detected. Replaced crankshaft sensor. Still will not start Code is still there won't start. And it has P0462 Fuel level sensor shorted to ground. Not sure what to do with this code. Any help would be great appreciated.
Those are both signs of a bad ECU. Was it jump started recently or have a bad/loose connection to the batttery?
Yes it has had a bad connection at battery with old battery loose post and bolt looked to be jumped. Fuel pump did not come on with Candoo check so I replaced fuel pump now that had fuel pressure and you can hear just to give everyone full story. Previse owner said it lost power and quick running.When I pulled the crankshaft sensor oil poured out also. I do not think that was normal. First 4tech bought by me.
