2006 Seadoo RXP cluster wiring
GregMcF
I’m trying to figure out what went wrong.
I’m in the process of building a jetboat and I have the engine/everything from a 06 RXP 215 in the boat.
As of today, the cluster has stopped working. I had zero issues before with it. Fuel pump primes, motor turns over (not sure if it will start, I literally got to the point of starting it today and now this) I have not changed anything with the wiring as of yesterday/today
I was welding on the boat with the battery disconnect in the off position. I assumed this would be enough to not fry the computer but now I’m not sure.
I have continuity though all 4 wires. The 2 white/other colour wires show 5 volts. The black Shows continuity back to the ground. The Red/Blue wire shows continuity to ground as well (I thought this was the power… is this my problem?) I thought maybe I pinched the wires but no fuses are blown.
