carlos_fig
Hello there. so last year I purchased this seadoo for a very low price knowing it had some engine problems. so being that the craft was in very good condition and I'm pretty savvy with small engines I took on this project . I did a compression test and found it to be low so i removed the top piston cylinder cover and seen damage on the pistons so i went ahead and removed the engine knowing that at the very least i will be doing a top end rebuild. so correct me if I'm wrong but isn't piston scoring usually caused by not enough oil? because i checked the main oil line from the tank and there are no obstructions . the oil flows no problem . i also manually checked the oil pump by turning it with a drill and it seem to be working just fine. so my question is what could of caused this problem? i aready have a oversize piston and cylinder kit i had purchased from sbt a coupled of months ago. I'm trying to figure out the root of the problem the last thing i want is to trash a new piston and cylinder. any help would be appreciated thanks.
