'20 RXT-X: 3 yr old gas, definitely clean carb?
stu_
Hello, I have a 2020 RXT-X 300 with less that 10 hours on it. It's just been sitting for 3 years (2 1/2 yrs indoors) with about 8 gallons of 93 octane non ethanol gas in it (18 gal tank). I got all the old gas out, and have fresh 93 octane non ethanol gas in it now. Full.
I have not tried to start it yet. Should I? Or should I definitely have the carb cleaned first?
Thank you.
Stu
Well, you don't have a carb so.....
All 4-stroke skis are fuel injected.
Drain the old fuel out, put in fresh fuel and ride. A little something like SeaFoam or Techron can't hurt either but isn't necessary.
I just was reminded that it doesn't have a carb on it. So I can probably just start it up. But it's been sitting. What about Dry rotted O rings or impeller or other things?
Thank you.
Right, someone else just reminded me. Thanks for replying. What about dry rotted o rings or impeller? Thanks.
I should add, if it has been sitting that long standard maintenance should be done such as oil change and spark plugs.
It's a brand new machine with only 6.8 hrs on it. I'm planning on a 10 hr "break in" oil change. (and filter)
Should I stick with that, or do it now? And spark plugs?
Thanks mikidymac
If it has been sitting almost 3 years change the oil before running it and then at 10ish hours. Oil is cheap, engines are not.
