Hold your horses!.............
I think there are several comments here that are either obsolete or inaccurate.  I've never heard of a 2 stroke being illegal........
In days gone by, we used to premix 6 gallons of gas with a small bottle that was the correct amount of a 50:1 mix, for running in our 2 strokes. But, that method caused them to not only smoke, but blow oil everywhere!  You could see a sheen behind a stroke a mile long.  The reason was because, at high speed rates, we got the engines hot and burned off most, if not all the oil.  In an idle situation, we blew a lot of that oil out the back.....environmentalist screamed.
Now, with the VROI,(Variable Ratio Oil Injection) pump, we only pump in the oil that we are  going to burn, therefore, leaving no mask of smoke to contend with.  You may see a little steam.....
But for the best part for last..........the 2 cycle engines use the roller ball and needle pin bearings.............they can last a life time.  The bearings in a 4 stroke, are like that of a car, or 4 stroke motorcycle.  Made with babbitt in them.  Your oil gets hot or your engine overheats, you wipe that babbitt right out of that main journal.( if the Oil Temp. Sensor or any of the multiple safeguards should fail)
My 787 is going to last a lot longer than your Super Charged 4-TEC, or if it lasts as long as mine, at least I won't have to spend the kind of money that your going to have to put in it to keep it running in top form, especially if it's Super Charged!..................Yes, I'm a 2 cycle man!...:cheers:
