Nosnibor
I'm back, more questions...
1. I was getting a little familiar with my boat today. I took the engine cover off and was trying to identify parts with my very limited mechanical knowledge. While scouting around what I think was the bilge pump I saw there is a section in the hull that rises up and back down. Kind of creating a section between the engine and where the gas tank are. On the engine side I noticed a little pool of water. I also noticed that area is where the drain plugs are. Is there something I should be worried about or is that just typical water that will drain out?
2. I haven't really lubricated anything since I have owned the boat. The owners manual recommends lubricating several things every 10 hours of use in salt water. Now that I am near 20 hours I wanted to make sure I touch up those areas even though I haven't had any issues yet. In the manual it shows this little tube near the oil dip stick. Am I just supposed to shoot down there and it takes care of everything? Also should I be spraying around the jet gate area and is there anything I should make sure I don't hit? I'm just using wd-40.
Thanks for any info.
