2 gti's 2 bad rod bearings
Gemfan
Hey Guys, My neighbor bought 2 2002 GTI's used, after enjoying them for awhile ,both have 1 bad rod bearing. Is this a common problem? any ideas? How much oil should stay in the bottom end to lubricate the crank and bearings?
THANKS
Both supply and return lines have plenty of oil. He was told to use seedoo mineral oil, Is this correct?
yah, but the rod bearing/s are lubed from the oil/gas mix...if these skis have blockoffs, then someone forgot to add oil, or oil pump failed/clogged.
Both motors are apart ,no doubt about bad bearings. If the rods are lubed by the fuel the what are the large oil lines on each side of crankcase?
