Hello
I picked up a 1997 Challenger single 787 engine. I am not getting spark on both plugs, changed stator to new OEM one as well as used coil pack pulled from a working machine, no change. Checked ohm values from service manual on: pickup coil (voltages 0.5v), stator, ignition coil pack & cables, all look good.
MPEM beeps twice when I plug the Dess in and engine cranks no problem. I am starting to think it could be MPEM, any way to confirm this? I see the white cable that goes from MPEM to coil pack and it showed me voltages all over the place, how do I test and confirm that its sending signal? Could it be a failed CDI? which is built in to MPEM on these years. Or maybe the pickup coil isn't functioning correctly even though readings look good?
If it is the MPEM, any aftermarket solutions? Would like to get engine running before winter
Any help is appreciated guys!
