1996 XP running problems
Birdman310
I bought this 96 XP about a month ago I took it out 2 weeks ago was having problems with it getting going in the water , but after 15 minutes of putting around it seemed to fix itself as if it just was cold, or hadn't been run in a while or something. Well I took it in to get a new impeller and wear ring on it an the mechanic guy started it up , and 10 seconds later it started running like crap, like bogging down and acting like its not getting gas or running on both pistons............So I took it home check the spark plugs there fine and they spark just fine, then i checked the coil and it was fine i even swapped coil assemblys with my 96 gsx same coil, and it worked just fine. Then i did a compression test each one running at 150 each. Only thing me and my dad can think of is its not getting enough gas for some reason, and we were curious if this XP has a fuel pump or not and maybe that's clogged or something, or there something electrical , but doesn't make sense how it starts up for 10-20 seconds and runs just fine and revs fine but then it just starts to run bad. Can anyone help Please!!!!!!!!!!!!!!!!!!!!!! Also wondering if anyone near Los Angeles knows any good mechanics to take it too cause the 3 places i know of don't work on anything 01 and older, so please anyone that can help it would be much appreciated, thank you-Birdman
I'll be at Puddingstone Lake tommorrow...If you want, pm me your number, afterwards, i'll be in La Habra for awhile, so...i'll take gander at it/rip carbs apart, clean raves...?
Whats the honey and lesbian part about? LOLOLOLOL! I just wanna have this fixed by the 16th so im really just looking for a mechanic that specializes on pwc's or can just give me a price adn have it done before that date.
Id take timmyboy over any mechanic anyday. Trust me, he WILL get ur ski fixed, and runnin' right.
i'd give tommyboy a shot at it hes really good at comming up with stuff to check and try. Have you tried running any carb cleaner throught it. The ski might have some varnish in the carbs or fuel selector.
Check the water seperator bowl for missing O-Ring. If this is missing or worn the fuel lines are sucking air and causing it to stumble. Try a inline fuel filter in its place $2.00 at auto store. I tried this and my ski is like new after doing all the other suggestions online (new fuel lines, carbarator overhaul and fuel selector valve).
check the small filters in the carbs behind the diaphragms. Mine were plugged solid causing the same issue. You will need a pair of needle nose pliers to pull them out.
Thank you all for your help and advice its starting to become clear what the problem is with it, If timmyboy is down then ill for sure have him do it if hes up to and lives close enough. Thank you all
LOLOLOLOL and now it runs perfectly fine, started it up l.ast night was stil doing it , and then i started it up just now thing runs fine, must be some dirt in the carbs or something.
