orbit398
Hello,
I recently purchased a 1995 XP. The multifunction gauge doesn't work and I am trying to figure out why. Nothing is "on" in any of the displays within it. I checked the fuses in the electronic module box (5 amp and 15 amp) and they are both good. The 5 amp is the one I am interested per the diagram below as it appears to power the gauge.
Per the wiring diagram in the service manual, I followed the RE-PU (red/purple stripe) wire to the connection under the hood going to the gauge (see red line in diagram pic). At this two wire connection, I do have battery power, so the circuit is good up to the gauge. I also checked the BK (black) wire to make sure it is grounded (see blue line in diagram) and it is indeed grounded. So power is to the gauge and it's grounded.
Question - the manual says it's an LCD type gauge. I have not seen one work before and wonder is should be showing something. Anyone comment on that? Being there is nothing showing in any part of the gauge, is it just bad?
Btw, the Tachometer and VTS gauges both work.
