shattered00
I feel like I am making too many threads, so moderators, if I am please let me know. I thought about continuing to post in some of the other threads I have started about other problems or just having one thread to contain all of the issues I have or will be running into (similar to a restoration thread) but both of those options seem like they might be too disorganized.
Fuel Baffle
I am cleaning up this ski while I await an engine rebuild and decided to take out the gas tank because of a non-functioning fuel gauge (and also to clean up a major oil spill). I have read the thread by RX951 and kustomkarl's post about the problem and solution but I am unsure if I messed up by draining the tank first. So the floater has no magnets on it and I feel it is likely the sole problem but assumptions... I do want to test to make sure the fuse isn't blown while I have the baffle out, however, the tank is drained and I have never used an Ohm meter before. I own one now, but am unsure as to what some of the below means.
"You need to check the Pink and Pink/Black wire coming out of the baffle tube in the gas tank. The sending unit works off resistance. Pull the plug apart at the tank, and use an ohm meter to check for resistance between the two pink wires. The resistance will be different depending on how much fuel is in the fuel tank. If you get no resistance, remove the clamps off the sender, and pull the sending unit out of the fuel tank. Check the magnets on the float in the sending unit. To get to the float out, pop the bottom off and look for the 4 magnets on the float. If they are missing use a strong magnet to get them out of the tank bottom. If they are dirty clean them and re-insert it back in the baffle tube and check the wires again to check for readings of resistance depending on where the float is in the baffle tube. Check the float to see if it “floats” in a cup of gas. Sometimes the float becomes saturated and won’t float in gas…but it will in water, so use gas to check it. If still no reading of resistance replace the sender. If you get readings, check continuity of wiring to gauge. At the baffle you could unplug the gauge and using a jumper wire between the 2 wires in the plug on the gauge side. Attach the lanyard to power up the gauges. If the gauge goes to full the gauge is good. If it still doesn’t respond, do a continuity test of the wires to the gauge. If all wiring checks out ok, and the gauge still doesn’t respond, the gauge is bad. Keep me posted on your progress.
The fuses are in the front box and the rear box."
-Karl
So I need to put some fuel in the tank, put the baffle back together and in, and put each of the probes from the Ohm onto each wire (one metal piece per wire). If it has some resistance (a reading on the Ohm meter?) then that means it is the gauge and/or the float but not the sender or the fuse? Or can I get no resistance with a non functioning float and thus I cannot isolate if that is the sole problem until I fix the floater? I do not have a strong magnet and have tried to see if the 4 magnets are in the fuel tank but cannot spot or hear any by shaking it and listening for a sound. I did not try to put the float into fuel to see if it floats because it looks and feels like it has become too saturated. Apologies if this process seems straightforward and I just don't get it.
Also, CoastieJoe mentioned an updated magnet. Is it part number 295500438? If so, I might as well buy three of these since I doubt the two 96s have been updated either.
Hull Damage
In my quest to clean this ski up, I observed a mouse skull and some beads of Styrofoam that were chewed off. It does not appear that it was a significant amount of Styrofoam (small chunks here and there and a larger chunk near the exhaust pipe. No wires appear to have been chewed. What I did notice as I was scrubbing the inside of the hull with a soft bristle brush and purple power was that some of the fiberglass came off. One spot was near the driveshaft where I see too divets. One of the divets did not have anything covering it, but the other had a piece that just flaked off. Another spot had what appeared to be congealed fiberglass material that looked like seaweed which was filling in a gap. I can now put my finger under this gap and move the entire fiberglass section (almost like a a piece of metal) up with my finger. I do not know if either of these could pose any major problems such as structural integrity. What do y'all think?
As always, thank you for your information and assistance.
Fuel Baffle
-Karl
Hull Damage
