I've replacing the thru hull fitting and the seal carrier assembly (with the seals and needle bearing) on my 1995 GTX. I've discovered that the rubber boot that is supposed to be up from the seal carrier is non-existent. From the looks of the parts and repair catalog diagrams, the fat end of the boot (part 272 000 001) clamps around the PTO flywheel. It looks like the smaller end clamps around the driveshaft? Is that right? I'm going to order a new one, but somewhat confused exactly what 2 areas in the driveshaft train it clamps to. Does the rubber boot rotate?
