I replaced the stator it ran for 5 mins and it died. No double beep no nothing. I go back to ramp and the 15 amp was blown again. I read you can troubleshoot it by disconnecting the center plug on engine and if the fuse doesn’t blow it’s the stator. Well after I disconnected the middle plug on engine then replaced the 15 amp fuse it blew again. First is that the correct what to troubleshoot it? What could be the issue?
