12v Low
RiverHock
own (2) 2001 SeaDoo GTX-DI's, today one started with Maintenance light on and 12 V Low readout? maintenance light keeps flashing, watercraft will not get up over 20 MPH, seems to be in Limp mode possibly? anyone have any suggestions please help, thanks much. :confused:
Charging system....
You need to get a voltmeter and see how much charge you have going to the battery when your running........you should be greater than 14 vdc.....:cheers:
Check the Voltage Regulator/Rectifier. My 2001 GTX DI was doing the exact same thing and replacing this fixed the problem. Good Luck!
