09 Seadoo GTI 130 Finger Throttle
kazanka101
Hello,
I was googling around and find a couple threads on it but can't seem to find the kit anymore. I have a 09 Seadoo GTI 130, and was looking to change the throttle to a finger throttle vs thumb.
I found the RIVA RS2455 Throttle Conversion Kit but it doesn't appear that it is still made today. Is there any type of conversion kit that would work for this or am I just out of luck?
-Thank you!
With a little will power you can take any finger throttle that will accept the cable end of the seadoo and make it work.
There's people that have used a bicycle brake lever even lol.
The 'kits' typically come with a block off plate to give it a clean factory look, that is what you'll really be missing. I bought an 06 RXT this past summer and was also looking for a kit I found referenced and realized it isn't made any more (or i couldn't find it). Next Spring I plan on taking my thumb throttle apart and making a plate with my 3D printer.
hi, were you able to design and successfully 3d print an adapter plate for your finger throttle? if so, can you share the .stl file? i would like to try it out on my 04 GTI LE RFI.
Unfortunately I haven't been able to find the time to do it yet. Will keep you posted.
