Ajent
Hi! New member, have been lurking for a while now. Trying to decide if my new-to-me challenger is running too hot. Here's the story:
Bought boat, went for first long run after water testing. It ran great, good power etc. Threw an over heat, p1116 after going almost full Throttle for 5 ish minutes. Panicked and let it idle, buzzer shut off almost instantly. Checked engine, exhaust cool to touch, engine hot. Ran it the rest of the day under less throttle, no problem. Took it home, flushed and changed coolant. Found ride plate horribly corroded, sanded it to bare aluminum again. Brought boat out another day and brought a good ir temp gun. Had a friend drive and I sat and watched temps. At a 35 mph cruise, front of head is about 200, valve cover at rear about 210, coolant at temp sensor is about 190, 195.. Coolant to ride plate is about 180 and comes back about 160
Crank it to almost wot and cruise at about 47, temps are up to 218 at front of head, 230 rear of valve cover, temp sensor at 215, ride plate at 195 and 165. I think it would have gotten hotter if we ran longer, but it was a 5 minute run, so roughly what set it off before. temps drop fairly rapidly once you slow down.
Am I overthinking it or is that just too hot? Any ideas or suggestions? Has anyone else ever checked running temps like this?
