New to this forum and to Sea-Doo ownership. I'm a die hard do it your selfer and look forward to collaborating on this forum!
Couple weekends ago we sucked some rocks into the pump and seized up the impeller. The impeller housing is damaged where I would call the diffuser? See pics attached. I'm assuming this can create some cavitation so I want to replace but when searching the parts it looks like this part is no longer available. Amazingly it is some kind of plastic so hopefully it has been upgraded!
Original part number not available is 271002161, I think? I have found a couple replacement part numbers online 267000417 and 461998. Can someone advise what the proper part is for this housing and what other parts I need to replace with it? I'm assuming I should replace the bearing. I already have a new impeller and wear ring. I included a pic of a few of the rocks casing the problem.
