08 Challenger SE 430 RPM's
bclinuxco
What RPM's should expect my Challenger engines to be turning on top-end?
I am seeing 7700-7800 RPM and want to make sure that my motors are performing as expected and I'm not about to experience supercharger issues.
Brian
Your rev-limiter is at 8300 RPM's. I think "Peak" hp is at 8000 RPM's. So... if you were out on a hot/humid day... then 7800 rpm's is expected.
The RPM's are just a little low... but not bad enough to say there is an issue.
Thanks! The RPM's may be a little different due to the Solas 14/19 implellers that I just put on instead of the OEM's. I just wanted to make sure that sounded "in-range".
