coolheiser44
Hi guys,
Here's the deal - when the boat is cold, and only at idle, the engine will start making a very strange and bad sounding noise. Watch the video to see what I'm talking about:
[video=youtube;wz6qxrzsEfg]https://www.youtube.com/watch?v=wz6qxrzsEfg[/video]
In the video, the boat starts out normally...then listen to the bad noise begin at 12 seconds until I shut it off. Then I re-start it and it sounds normal for a few seconds...until 33 seconds in the video where the bad sound happens for another 5 seconds or so.
Ignore the 12v low on initial start-up - that's not the problem (as it's been doing this for a long time, even with fresh battery). I have received no check-engine or warnings. When revved up even the slightest bit the noise goes away and it doesn't do it when it's warm. The engine performs and behaves normally otherwise. The RPM's aren't going down below normal idle (around 1800rpm) according to the dash, but it sounds as though it's bogging down...
Do any mechanics or knowledgable SeaDoo guys have any idea on what can be the cause of this?
