Sofla Member Apr 23, 2020 #1 Experiencing a single intermittent alarm . At idle, in the water. Intermittemt at idle, if i were to try to throttle up it sounds same single long alarm. immediately Anything to decifer from this little bit? Thank you kindly
Sofla Member Apr 24, 2020 #3 I have the 215hp SE model, the 1503 4 tec 4 stroke rotax SOHC Specifically, the boat model is the 867F
T Tim75 Well-Known Member Apr 24, 2020 #4 Sofla said: I have the 215hp SE model, the 1503 4 tec 4 stroke rotax SOHC Specifically, the boat model is the 867F Click to expand... I don't think you will get much response here. This is the MERCURY section.
