07 challenger 180 se lights/gauges
Albysure
Everything is working on the boat as it should except my gauge will not light up...I thought it shared the same fuse as the nav lights.....fuse is good....is there any other fuses I should check? Just got the boat with no manual...gotta order one...
Thanks in advance
What about bulbs?
I'm going to check that next....there's a good number of bulbs in there...unless there was a short of some kind and blew all at once...does it just light up white or is there other colors in it for different warnings?
Thanks
Most likely bad switch. If you have rocker switches they need cleaning. If you pull your panel, it's the blue wire for the lights.
Get a meter and see if the HOT wire is providing volts. Try a few different groin areas. If no power, trace the wire back and see what feeds it.
