When i plug my Des in and the computer starts up the right side tach wraps around past 8000 rpm and once engines are started it reads minimum 1500 rpm higher. I have switched the mulnex plugs from one engine to the other and the tach still does it when hooked to the other engine. question is do i have a dead tach or should i try to calibrate it??? problem was intermitent at first but now is continual..
