I have a 2006 GTX 185 SC that I picked up for cheap because the supercharger let go. I rebuilt the motor to spec from the manual. Rebuild included rings, bearings, seals, gaskets, supercharger, both oil pumps, valves cleaned and lapped, valve seals, impeller and wear ring. Upon first start up I noticed it sounded like it was only running on 2 cyl. So far my diagnostics have consisted of:
1) I pulled the coils one by one as the engine was running. There was no change in engine performance when I pulled coil #2. There was a change in performance on coils 1 and 3. To confirm this i swapped the coils around and the problem still stayed on cylinder #2. My conclusion would be that the coil packs are good. I checked resistance in both windings and they all checked out.
2) I checked for 12v coming from MPEM on each connector for each coil. All were good with 12v.
3) I checked for voltage on the ECU switched ground side of each connector for each coil. I got around 1v or less on each one. Should there be any voltage on these wires since they are supposed to be switched grounds? Seems like there should be no voltage at all there.
4) checked for continuity and resistance in harness from "A" connector on ECU to each coil connector ground side. All had continuity and all have .6 ohms resistance. Should there be any resistance on these wires?
5) checked and cleaned all ground connections on the block and battery.
**I should add that codes for the crank sensor and the cam sensor have activated randomly but if I turn the ski off and wait a few seconds the codes go away and the ski starts up fine. The ski will intermittently smooth out like its running on all cylinders but only for a few seconds and then back to misfiring. I am starting to run out of ideas on what it could be. Any help or info would be GREATLY appreciated. Thanks in advance and happy safe riding!
