'06 blower question
mrfixitct
blower not working, have 12v at fuse, fuse definitely good, no 12v to switch and obviously to blower motor, I doubt a physical wire issue, any thoughts? before I hard wire 12v to the switch and be done with it.. The wiring does appear to go the block where fuse box is, no idea what that block does..
thx!
no?
thx!
no one evr had blower issues? :)
Nope - I wouldn't be surprised if they eventually fail though as it would be easy to get water down the vent on to the fan. Use a circuit tester to check power to the fan, then you'll know if it's the fan or not.
no power to the fan, no power to the switch as far as I can tell though the fuse for the blower has power and fuse is good. Wiring appears to go thru this big black mystery box thats purpose I have no idea..
