05 Speedster 200 185SCx2 Knock Sensor
lilngineer
Hi-
Boat has exactly 100 hours on it and threw a knock sensor code. Any ideas? Defeat reset but it's still present. Been running 87 in it. Bad gas? Bad sensor?
Any help is appreciated!
I believe you need the higher octane fuel being that your motor is supercharged.
check the wire harness/connector. check sensor to engine is clean and check bolt torque.
i think if you remove key, it should remove fault so you can start. rev to 5000 rpm and see if fault reoccurs. bad fuel or sensor.
i always use 98 octane, just my thing....
You mean 93 octane? I use 90 octane, ethanol free gas and have no problems with knock but only reach 7800 rpm's. That is not a problem for me since wide open I go 46/47 mph but 99% of the time I ride the SeaDoo at 6000 rpm's and travel 29/30 mph.
AU has a different octane rating system
we also have 87 and 91 thats why a little confusing.....
found this to explain, sounds right?
aus uses the ron measurement
As you know, the "octane number" is a measure of a fuel's anti-knock (or pre-ignition) characteristics.
There are different accepted standards used to measure the anti-knocking characteristics of gas. The octane number you see at US pumps is the average of two such octane numbers; the Research Octane Number (RON) and the Motor Octane Number (MON). This average number is sometimes referred to as the Anti Knock Index ("AKI") or the US Cost of Living Council method ("CLC"). The RON and MON numbers are determined by American Society for Testing and Materials ("ASTM") laboratory tests. Thus, US octane numbers are described as, e.g., 93 AKI or 93 CLC. The equivalent RON number in other countries would be 98.
The RON method determines low speed and low load knock characteristics while the MON method tests high speed, high load, high temperature conditions such as exist during periods of high speed power accelerations, hill climbing, or any period of high power output. The MON method results in a higher octane number & is the more relevant value for racing.
Maybe more than you asked, but ... .
