With 38.5 hrs. 143.8 miles a filter change around 10 hrs. and oil and filter change at 24 hrs. I am getting #1 dry 110psi wet 135psi, #2 dry 130psi wet 150psi, #3 dry 130psi wet 145 psi 30w oil use for wet test. Is there a way to check to oil pressure with a gauge?
Any suggestions?
Put it together and run it?
Possible s-pipe leak?
Intercooler pressured up with 40psi water pressure and no visible leaks.
Any suggestions?
