I isellcarz New Member Jul 11, 2008 #1 I have a 2005 Sea Doo RXP 215 HP Took a compression test and the reading were: Cyl 1 150psi Cyl 2 0psi Cyl 3 150psi What would cause this and has anyone else had this problem. The machine has only 35 hours on it. Any suggestions?
kustomkarl Premium Member Premium Member Jul 11, 2008 #2 It could be a bent valve thats stuck open...or a blown piston...What lead up to this problem? Karl
RX951 New Member Jul 11, 2008 #3 Pull the top valve cover off and check to see if the timing chain didn't break.
