04 sportster 150 neutral start switch?
travisray91
Premium Member
Premium Member
Hey all, new to forums here and have a particular problem with my sportster.
First of all, while attaching lanyard i do not here the usual 2 beeps Then it will not turn over but engages the fuel pump. I checked all fuses and its all ok. I also get a quick blast of 4 beeps every two seconds. I have read this pertains to the position of the shifter lever not being in neutral. I can confirm the neutral position but i cannot get the beeps to go away. Upon restarting, same results.
Has anyone had similar problems or have any experience with neutral start switches? Is this a common thing to go bad?
Thanks for any info its much appreciated.
Not as common issue, but it can happen.
Lift the lever assembly out of the hull, and check the switch.
