tamarack_34@hotmail.com
I have a 2004 Sporster, single engine, 4 stroke. I changed the spark plugs, fired it up, it ran a little rough when i gave it throttle which I was going to dig into. Shut it down. Went back about 15 minutes later to try it again and start thinking about rough running issue, i plugged the lanyard in and no beep, not power to gauges, nothing. Tried the start button and of course nothing, no clicking or anything. Checked to be sure my battery was on and then tried blower and it ran fine. Charged the battery just to be safe even though I had just started it with this battery, no difference. The fuses in the little fuse box in the dash were ok and the fuses in the box against the port side engine bay firewall were ok. Is there a fuse somewhere else that would affect the DESS key?
Oh I tried my key on my RXP and it beeped the wrong code beep and tried my RXP key on the Sportster and of course it was dead silent.
Should there be 12 volts on either side of the DESS receptical that I should check for? What causes no beep at all when the battery is good and the battery switch is good?
Appreciate anyone's thoughts.
John
John
