04 gtx filter kit
More info?.....
I'd need more info on what type of mod you did for your supercharger.
But generically speaking, the crankcase ventilation on a 4 stroke motor usually vents to the air induction system so that any vapor can be burned off before going into the atmosphere. For a ski, this would be a good idea so that explosive vapors did not get trapped in your hull. But if you have the maker of your power filter so I can read about it, I can give you a better answer.:cheers:
air filter
its a home made one 3 inch dia tubing to a 4 in k&n filter . unsure what to do with standard air filter unit and wires connected to it the crank case hose i could prob feed into the air filter hose i think ? thanks h
........it works.
Yes, with the mod your doing, "shadetree mod", ....you can run the crankcase ventilation to the air induction system. I hope all works out to your advantage.....
