03 GTI no start/Spark
chukenne
I have a 2003 GTI and ste starter solonoid clicks but does not turn the engine over, you can jump the solonoid and it turns over fine. also no spark when it is turning over, it also beeps two time whe you first plug it in then it beep 4 beeps rapidly, any advice on this issue?
4 beeps?.....
The 4 beeps your hearing is a warning to the operator that you left the lanyard cap on the post. It's a feature to remind you that the ski is powered up and if you walk away from it, you'll likely return to a dead battery.
If I understand this correctly, you can put the lanyard on the post, get the two beeps, push the start button and it only "clicks". Then, you can put the lanyard on the post, get the two beeps and when you jump across the starter solenoid, it will spin but there is no fire.
Did you check your fuses?.........
I checked all the fuses and ohmed them out all checked good, there are four fuses in a row on the main black box when pluged in only two have 12vdc??
Power.....
From what I see of your electrical drawing, you only have two fuses that should be live, the rest are spare. The bottom two fuses are the battery, 15 amp and the MPEM, 5 amp.
Do a continuity test on the BK/PU wire from your DESS switch to your BK/PU wire at your cut-off relay switch, which is right beside your solenoid.
Connect your lanyard to your post, check to see if you have power from the YL/RD wire at the solenoid when you press the start/stop button.
With the lanyard still in place, take a reading on the coil for continuity using the black and white wires going in. Then, using the black connector in the center lug (ground) of the coil, check the power on the BK to White and Black to Black ..........let me know what you find out.........:cheers:
here is what I have for you:
Continuity on the bk/pu wire from end to end has good continuity.
with the lanyard connected to the post while pressing the start button I have 11.33 vdc and the solonoid just clicks.
with the lanyard still in place I have .8 ohms and no power to either wire to the coil.
Beeps?....
In your first post, you said it beeps two times when you connect the lanyard. Does it beep two times every time you put the lanyard on.
It sounds like (but to confirm this, more troubleshooting is needed) you may have a problem in your mpem, but lets continue as if it's o.k.
Have you tried the advanced diagnostics mode on the DESS yet? And I take it you had no power on the YL/RD wire.
