killswitchone
Hello all,
I own a 03’ GTX 4-TEC non-SC. The information center does not turn on. Tachometer and speedo also failed to turn on. I checked supply voltage to the info center and I have 12V measured at the connector under the hood behind the access panel. Communication wires also checked out good. I don't have any burnt fuses nor loose wire connections. I'm suspecting a faulty Information Center. My problem is removal of the info center. I downloaded the service manual and read up on it. I tried using a suction cup but was unsuccessful. Is there any clips holding the info center that I'm not aware of? Any tips on removal?
Thanks in advance.
Thanks in advance.
